Hublot King Power Usain Bolt Watch
milan zmaj
za najbrzeg...48 mm keramika....limitirana serija od 250 komada..eh ovaj bi uzeo,lepa kombinacija boja
Baš htedoh da prokomentarišem da je kaiš baš bzvz... Pa videh da je napravljen od iste kože od koje su bile napravljene cipele koje je "Najbrži" nosio pri obaranju svetskog rekorda u Pekingu 2008. godine. :stupid:
Pridodajem teh. karakteristike, oprostićete bez prevoda:
KING POWER USAIN BOLT
Reference: 703.CI.1129.NR.USB12
Series: 250 pieces numbered from 01/250 to 250/250
Case: "King Power" - Diameter 48 mm in micro-blasted black ceramic
Bezel: Black ceramic
6 black PVD H-shaped relief titanium screws
Crystal: Sapphire with grey minute track transfer
Interior/exterior anti-reflective coating
Bezel: Lugs Black composite resin
Lateral inserts: Black composite resin
Case-back: Micro-blasted black ceramic
Silhouette of Usain Bolt on sapphire case-back
Crown: Black PVD titanium with black rubber insert
Push-pieces: Black PVD titanium with black rubber inserts
Screws: Black PVD titanium
Water resistance 10 ATM or approximately 100 metres
Dial: Matt black, circular satin-finished flange with 2N gold coating
Satin-finished and black nickel-coated indexes with black SuperLuminova™
Transfer of Usain Bolt's silhouette in meteor grey at 9 o'clock and 2N gold powder Hublot logo
Hands: Satin-finished and black nickel-coated with black SuperLuminova™
Movement: Calibre HUB4100
Mechanical chronograph with automatic winding and central seconds hand. Small seconds at 9 o'clock
No. of components: 252
Jewels: 27
Date: Date window at 4.30
Power reserve: Approximately 42 hours
Strap: Adjustable in black rubber
Made from the same gold-coloured synthetic leather as Usain Bolt's shoes.
Clasp: King Power folding buckle in black micro-blasted PVD titanium
Micro-blasted black ceramic decorative plate
