Tissot luxury automatic 80h power reserve
vanjabg77
Presented Dec 2012
Size-Gent
Case material-Stainless Steel
Water resistance up to a pressure of 5 bar (50 m / 170 ft)
Glass material-Sapph. Crystal+Non-Reflec Coat
Dial color-Black-White-Various
Dial type-Index
Bracelet material-Stainless Steel -Leather
Movement caliber-Powermatic 80
Movement type-Automatic Mechanical
Weight-82g (Leather)
Diameter-41mm
Height-9.75mm
Tissot has been working hand n hand with ETA for the research and development of this new automatic piece. Together they thrived to push the limits in terms of precision, power and essentially giving time a new status. Tissot’s spirit of innovators by tradition and ETA’s expertise in the creation of movements is a winning combination. Both companies were able to carry each other above and beyond, leading to the production of a ground-breaking piece.
Tissot’s recipe for success is to ally its watchmaking expertise and traditions to the benefits of innovative materials, which has proven itself time and time again. This movement was no exception to that approach and as a result, the automatic Powermatic 80 not only demonstrates ultimate precision but also has 80 hours of power reserve. Additionally, staying true to Tissot’s philosophy of offering luxury products at an affordable price, you will be awestruck by the price of such a revolutionary component.
Works
Standard watches would usually have a barrel that would last 36 hours before needing to be wound up again. However, with a new construction concept which integrates a new spring barrel, Tissot and ETA were able to provide the piece with a greater power reserve, allowing the watch to go for 80 hours without being worn or wound up. As if a greater power reserve was not enough, they also found a way of making the movement extremely precise and robust by concentrating on ways to improve the regulator system. One of the factors which contributed to that robustness was a new way of regulating the watch by removing the index-assembly system and replacing this item by an innovative technology.
This new way of thinking and essential modifications have given way to this brand new revolutionary system called the Powermatic 80 automatic movement. You may witness these works in the Tissot Luxury timepieces, the first watches to feature the ground-breaking piece.
Published in : Tissot, New arrivals
A cena jel se zna?:) Nisam je video mozda mi promakla:blushing: Sta znam nije los sat, sto se tice mehanizama, treba malo vremena da prodje da bi imali bolji uvid kakav je:)
Meni izgleda odlično, posebno crna varijanta sa kožnom narukvicom. A mehanizam me još više oduševljava, samo još da se dokaže u praksi. Nadam se da cena neće biti neka astronomska... Sve u svemu jedno prijatno iznenađenje od Tissota...:)
Hvala na infu o ceni:) Moracu da prenocim pa da bolje razmislim sta da mislim o ovom modelu , inace sve u svemu svidja mi se:)
Da ovaj sat sam još pre zapazila, posebno zbog tog novog mehanizma.
Neke njegove Hi-res fotke sa postavila OVDE.
Evo još nekih koje imam.
Tissot_Luxury_Automatic_COSC_T086_208_11_116_00_MT.jpgTissot_Luxury_Automatic_COSC_T086_408_11_056_00_MT.jpg
Pozz od mene! :)
Lepo, jednostavno, elegantno... Fino je da su se potrudili oko rezerve snage...cena: manje-vise OK. Svidja mi se gravura rotora i obrada strana kucista. ''Mother of pearl'' brojcanik je super (doduse, ovo sto je Shmizz postavila mi lici na zensku varijantu)
tja, nije lose, ali sta znam...
u svakom slucaju, za pohvalu je sto su poradili na mehanizmu, i u estetskom i u tehnickom smislu.
Sto se izgleda tice, nije lose, ali mu, bar za moj ukus, nedostaje "ono nesto" da bi bio pun pogodak.
Cifer mi deluje kao modernija, modifikovana varijanta vintage Seastar modela:
s tim sto je ovo neka minimalistickija varijanta, gde mi, opet, bode oci natpis Tissot i 1853, mogli su bar velicinu ili tip fonta da promene, da bude diskretnije, ili bar elegantnije. Ne svidja mi se narocito ni obrada kucista, sa tom gravurom. Sve u svemu, vidi se da su nesto 'teli, ali nekako mi je bez identiteta, i ne znam gde bih ga strpao - niti je elegantan, niti casual, niti sportski...
Meni isto vizuelno nije ništa posebno . U taj stil mi se ne uklapa šrafura koja je prisutna sa strane kućišta. Cenim kada neko poradi na inovacijama a ne bavi se samo dekorisanjem mehanizma. To je pohvalno.
Mogli su malo pojasniti šta je tačno urađeno oko regulisanja mehanizma umesto što kažu da koriste "innovative technology". Ne mislim da treba da otkriju poslovnu tajnu ali i ova fraza baš ništa ne govori.
Što bi rekli na ovom forumu kada počne rasprava Seiko vs Swiss , argumenti, argumenti :D.
Što se tiče ovog mehanizma,čini mi se nikakva osim što je dotjeran na -4+6 na 5 pozicija.
Na "standardnim" Eta tu se promjeni balansni točak,opruga,incablok.
Koliko vidim,ovdje nije ništa mijenjano(ne znam za oprugu).
